Layer renaming script problem
COW Forums : Adobe After Effects Expressions
Adam levine
on May 7, 2016 at 7:26:12 am
I'm a beginner for scripting and I created simple script for my own purpose rename layer for active comp and for all comps in the project. That 2 codes are ok. But I've no idea how to combined both of them to one UI. However I combined them. But in that script active comp part only working. can anyone help me how to fix that. I think Master Dan can give me an Idea to fix this :)
function stingStartsWith (string, prefix) {
return string.slice(0, prefix.length) == prefix;
app.beginUndoGroup("My Undo");
function allComps() {
for (var j=1; j&lt;=app.project.numItems; j++){
var comp = app.project.item(j);
if (comp instanceof CompItem){
for (var i=1; i&lt;=comp.layers.length; i++){
var myLayer = comp.layers[i];
var myLayerstartswith = stingStartsWith (myLayer.name, UI.mainTextGroup.mainText.text);
if (myLayerstartswith){
myLayer.selected = true;
myLayer.name = UI.secondaryTextGroup.secondaryText.text;
} else {
myLayer.selected = false;
function currentComp() {
var comp = app.project.activeItem;
} else {
} else {
alert("Please select a composition");
app.endUndoGroup();
function createUserInterface (thisObj,userInterfaceString,scriptName){
var pal = (thisObj instanceof Panel) ? thisObj : new Window("palette", scriptName,
undefined,{resizeable: true});
if (pal == null) return pal;
var UI=pal.add(userInterfaceString);
pal.layout.layout(true);
pal.layout.resize();
pal.onResizing = pal.onResize = function () {
this.layout.resize();
if ((pal != null) && (pal instanceof Window)) {
pal.show();
return UI;
var resourceString =
"group{orientation:'column', alignment:['fill','fill'],alignChildren:['left','top']\
mainTextGroup: Group{orientation:'row',\
mainTextLabel:StaticText{text:'Find', preferredSize:[80,-1]},\
mainText: EditText{text:'enter find text here', characters:40}\
secondaryTextGroup: Group{orientation:'row',\
secondaryTextLabel:StaticText{text:'Replace', preferredSize:[80,-1]},\
secondaryText: EditText{text:'enter replace text here', characters:40}\
compGroup: Group{orientation:'row', alignment:['center', 'top']\
currentComp: RadioButton{text:'Current Comp', value:true},\
allComps: RadioButton{text:'All Comps'},\
applyButton: Button{text:'Apply', alignment:['center', 'bottom']}\
var UI = createUserInterface(this,resourceString,"Layer Renamer v1.0");
if (UI.compGroup.currentComp == true){
UI.applyButton.onClick = function(){
currentComp();
}else if (UI.compGroup.allComps == true){
allComps();
Dan Ebberts
Re: Layer renaming script problem
on May 7, 2016 at 4:39:47 pm
Try changing this section:
currentComp();
allComps();
to this:
UI.applyButton.onClick = clickApply;
function clickApply(){
if (UI.compGroup.currentComp.value){
currentComp();
}else{
allComps()
Dan
Adam levine
on May 7, 2016 at 5:14:50 pm
Thank you master dan. It works perfect. I need a more help from you. In my script there's a little problem. If I set something text in the Find and the replace it changing whole layer name to the text I used as Replace text.
For example: But I want to do like this. If layer name is "My Layer 01" and I input to find text as "My" and input replace text as "White".
Then Layer name must change as "White Layer 01" . How to that?
Dan Ebberts
on May 7, 2016 at 5:29:37 pm
Here's a simple example that assumes you're replacing the first part of the name:
var replacementText = "White";
var targetText = "My";
var myLayer = app.project.activeItem.layer(1);
if (myLayer.name.indexOf(targetText == 0)){
myLayer.name = replacementText = replacementText + myLayer.name.substr(targetText.length);
Dan
Adam levine
on May 7, 2016 at 5:55:38 pm
Thank you so much master Dan. I need a little more help from you. Can you explain me this codes that you gave me.
Adam levine
on May 7, 2016 at 7:31:16 pm
I only want to understand this line
Dan Ebberts
on May 7, 2016 at 8:59:22 pm
That line just checks to see if the layer name contains the target text, starting at the first character of the name.
indexOf() returns the zero-based characer index of where it finds (searching from left to right) the first occurrence of the target string, or, -1 if it doesn't find it at all.
Dan
Adam levine
on May 8, 2016 at 7:24:02 am
Thank you Master Dan
