Timed Opacity expression
COW Forums : Adobe After Effects Expressions
Roy van Venrooij
on Apr 15, 2016 at 9:08:32 am
Hi all.
I'm a bit of an expression noob so forgive me if the answer is obvious.
I use this to check if the layer has any text, if it does the layer becomes visible. works a charm.
However the text layer is a subtitle which pops in and out quite a lot, causing the textbox to do the same.
I was wondering if it is possible to build in some sort of delay to the code so the box stays on 60 opacity for a time after the text has gone?
temp = thisComp.layer("&lt;empty text layer&gt;").text.sourceText;
textviz = temp.length;
if (textviz > 0) 60 else 0
