Possible to execute sequential linear calls
COW Forums : Adobe After Effects Expressions
Josh Peters
on Mar 8, 2016 at 5:17:11 am
Basically I'm trying to templatize some really simple moves for a bulk project. The concept is to use linear to build in animations based off the in/out point of a layer. The code below is just playing around at the moment but I can't figure out a way to get it to execute more than one linear command, is this possible?
key1=inPoint;
key1end=inPoint+.3;
key2=outPoint;
key2end=outPoint-.3;
Width=width*scale/100;
posx=640-(Width[0]+Width[0]/2);
linear(time, key1, key1end, [posx, 360],[640,360]);
linear(time, key1end, key2end, [640, 360],[850,360]);
Dan Ebberts
Re: Possible to execute sequential linear calls
on Mar 8, 2016 at 7:28:10 am
You have to combine them such that only one of them executes, so the last part would be like this:
if (time < key1end)
else
Dan
Josh Peters
on Mar 8, 2016 at 4:28:06 pm
Thanks Dan! I needed to get multiple else if statements in there and I think I was just structuring my conditionals incorrectly, what I posted below seems to be working pretty well. Now it's just a matter of building in some variables for positions.
key1=inPoint;
key1end=inPoint+.3;
key2=outPoint;
if (time &lt;= key1end && time>=key1)
else if (time>key1end && time&lt;=key2end)
else if (time>key2end && time&lt;=key2)
linear(time, key2end, key2, [850, 360],[1050,360])
