Walk cycle speed
COW Forums : Adobe After Effects Expressions
Sean Kimber
Walk cycle speed
on Feb 5, 2016 at 3:32:58 pm
I'm trying to create a walk cycle and have measured the amount the x should move for each step. The problem I'm having is I can't figure out how to make that speed work throughout the rest of the animation. I've used "loopOut("continue)" but since there are ease keyframes on the steps, the character slides a little bit. But if I put eases on my x position keyframes, the character stops and won't move anymore. How do I account for the ease keyframes and not have my character slide or stop?
loopOut("continue")
Miguel de Mendoza
Re: Walk cycle speed
on Feb 8, 2016 at 10:21:17 am
Maybe do you need to use a "cycle" loop:
loopOut("cycle",0)
Sean Kimber
on Feb 21, 2016 at 3:06:29 pm
Thanks for your help! That didn't work for me, unfortunately. But I did finally find the answer. When I substituted "offset" for "continue" it honored the ease of the keyframes.
