Combining 2 expressions on a slider control
COW Forums : Adobe After Effects Expressions
Buki Bodunrin
on Jan 18, 2016 at 6:12:23 am
Hi I'm having trouble getting 2 expression to work together on a slider control. Thanks to the wonderful Dan Ebberts, I'm using this expression to randomize a bunch of stills in a composition (http://motionscript.com/expressions-lab-ae65/random-stills.html). My trouble is whenever the slider hits a value on 1, no stills are shown. I'd like to add to the expression so that the minimum value never goes below 2. Dan's expression looks like this:
duration = .125; //length of each cut (seconds)
seed = Math.floor(time/duration) + 1;
seedRandom(seed,true);
Math.floor(random(1,index));
I tried adding this line of code after:
clamp(value, min=2, max=255)
But it doesn't work. What am I doing wrong? Or is there a better way to do this?
Miguel de Mendoza
Re: Combining 2 expressions on a slider control
on Jan 18, 2016 at 3:31:26 pm
You can change the random() min parameter to 2 like this:
Math.floor(random(2,index));
Or you can check the value with an if statement:
randomValue = Math.floor(random(1,index));
val = (randomValue < 2) 2: randomValue;
Buki Bodunrin
on Jan 18, 2016 at 6:41:08 pm
Ah...
It worked changing
Thanks again!!!
