Need to automate - rotate layer A from 0 to 30 then back to 0 while B is rotating 180 deg.
COW Forums : Adobe After Effects Expressions
Sasha dal Ponte
on Nov 19, 2015 at 2:34:09 pm
Hello!
I have two layers - A and B.
Layer A is linked to null and it is rotated from 0 to 180 deg.
Layer B is linked to layer A and it needs to rotate in a specific way.
When layer A rotation value is 0, layer B also needs to be 0.
When layer A rotation value is 45, layer B needs to be 30.
When layer A is 180, layer B needs to be back to 0.
That, of course, needs to be smooth, not in jumps.
So I need expression that would read layer A rotation value and rotate layer B accordingly.
Dan Ebberts
Re: Need to automate - rotate layer A from 0 to 30 then back to 0 while B is rotating 180 deg.
on Nov 19, 2015 at 5:52:05 pm
Something like this should work:
r = thisComp.layer("Layer A").transform.rotation;
if (r < 45){
linear(r,0,45,0,30);
}else{
linear(r,45,180,30,0);
Dan
Sasha dal Ponte
on Nov 22, 2015 at 9:14:28 am
Thanks Dan!
It works perfectly! I just adjusted 45 angle to 90 because I put it in wrong in original post.
