Pick whipping between comps. Error: Layer is missing or does not exist.
COW Forums : Adobe After Effects Expressions
Andreas Woelfl
on Nov 5, 2015 at 8:28:59 am
Hello everybody.
I am trying to organize my project and divide it in separate scenes.
Some elements will be present in every comp though. To avoid jump cuts of this elements I want to pick whip each instance of an element to the one in the fist scene.
The idea is to keep the project as flexible as possible. So if I move an element in the first scene, every instance of the element in other scenes will change its position automatically.
I did this already in a previous project but this time I got an error I do not understand. I pick whip the properties of the two elements and get an error telling me that the layer I just pick whipped is missing or does not exist (see adjusted screenshot).
Anybody can tell me what I am missing.
If there are any other suggestions how to organize elements across various scene to keep the linked to each other are am more that happy.
Thanks a lot and greeting.
Miguel de Mendoza
Re: Pick whipping between comps. Error: Layer is missing or does not exist.
on Nov 5, 2015 at 9:55:26 am
Can you copy here the full error code?
Andreas Woelfl
on Nov 5, 2015 at 12:40:34 pm
Hey Miguel,
here is the screenshot:
Xavier Gomez
on Nov 5, 2015 at 2:40:00 pm
Can it be that the project as more than one comp named "02 Scene", and the first one that appears in the project panel doesnt have the required layer ?
Andreas Woelfl
on Nov 16, 2015 at 11:36:53 am
Hello,
I haven't seen your response. In order to answer the post I was making test and I just realized that the pick whip is working now. I have no idea what exactly was the problem!
Thanks anyways for all the help!
