Interpolation - make it endless
COW Forums : Adobe After Effects Expressions
Zsolt Koppányi
on Oct 28, 2015 at 9:15:57 pm
Hello,
I'm new to javaScript,and was wondering how to achieve a pulse with Opacity changes not to use the traditional Math.sin() or Math.cos() method.
I'd like to use Interpolation methods to change Opacity from 0% to 100% and make it every two seconds and let these changes in this range last forever.
I know the classic interpolations, and I'd add the following expression to the layer's Opacity:
ease(time,inPoint,2-inPoint,[0],[100])
...It will change only the first two second. But what to modify to make it endless?
Zs
303450b93926828312687568
Dan Ebberts
Re: Interpolation - make it endless
on Oct 28, 2015 at 9:29:39 pm
Do you mean you want it to repeat? Something like this should work:
d = 2; // duration
t = (time - inPoint)%d;
ease(t,0,d,0,100)
Dan
Zsolt Koppányi
on Oct 28, 2015 at 10:32:07 pm
Thank you, It works perfectly!
That's what I thought about (repeating interpolation).
Just for satisfying my curiosity, what does the second row mean basically?
t = (time - inPoint)%VARIABLE;
Zs
Dan Ebberts
on Oct 28, 2015 at 10:42:18 pm
It just loops t from 0 to 2, every 2 seconds (starting at the layer's in point).
Dan
Zsolt Koppányi
on Oct 28, 2015 at 10:54:37 pm
Thanks, I've learnt a lot!
Zs
Zsolt Koppányi
on Oct 29, 2015 at 10:22:43 pm
A thought crosses my mind about using this modulo (%) expression. I noticed it works like loopOut("cycle") expression with keyframes. Is there a similar modulo expression which corresponds to loopOut("pingpong")?
The reason is to get a smooth (ease) reverse to the start...
Dan Ebberts
on Oct 29, 2015 at 11:19:25 pm
One way:
d = 2; // duration
n = Math.floor((time - inPoint)/d);
n%2 ? ease(t,0,d,100,0) : ease(t,0,d,0,100)
Another:
d = 2;
50*(Math.sin((time - inPoint)*Math.PI/d - Math.PI/2) + 1)
Dan
Zsolt Koppányi
on Oct 30, 2015 at 9:34:06 pm
Many thanks again Dan!
The first is a bit difficult for me to decode, however works as I thought.
Zs
Zsolt Koppányi
on Nov 2, 2015 at 5:57:18 pm
Hello,
I rewrote your first expression for two-dimensional properties.
I applied it for Scale and converted the ternary operator to if/else conditional (because it's understandable for me) but seems I made a mistake in it. Could you point at where I did it?
Thank you...
d = 2; // duration
if (value == n%2)
ease(t,0,d,[value[0]+500,value[1]+500],[value[0],value[1]])
else
ease(t,0,d,[value[0],value[1]],[value[0]+500,value[1]+500])
Dan Ebberts
on Nov 2, 2015 at 6:16:31 pm
Try changing this:
if (value == n%2)
to this:
if (n%2)
Dan
Zsolt Koppányi
on Nov 3, 2015 at 2:03:07 pm
Oh my... It seems I over-complicated the conditional...
With this simple modification it goes like a dream!
Thank you, Dan!
