Change opacity every n-frames
COW Forums : Adobe After Effects Expressions
Luis Garcia
on Oct 24, 2015 at 11:11:17 am
HI! I would need an expression to change the opacity betwen two values (30% and 0%) each n-frames.
I have 15 text layers with wiggle expressions, but 15 layers is too much. I would like some expressions to be able to show 7 text layers (with 30% opacity) for n-frames (imagine 18 frames) and then the other 8 text layers other 18 frames for example, and then appears again the first 7 text layers for 18 frames and every time with this secuence durinig all the clip.
Any idea to do this??
A lot of thanks in advance!!!
Good Weekend!
Dan Ebberts
Re: Change opacity every n-frames
on Oct 24, 2015 at 5:50:59 pm
You could use something like this for the first group:
val1 = 30;
val2 = 0;
n = 18;
f = timeToFrames(time);
s = Math.floor(f/n);
s%2 ? val2 : val1
and switch the last line to this for the second group:
s%2 ? val1 : val2
Dan
Luis Garcia
on Oct 24, 2015 at 9:44:08 pm
Thanks Dan, it works perfectly!!! A lot of thanks Dan.
I have another question... How I can modify this expressions to get, for example, three or four groups of text layers doing this....
For example:
Layer 1 - 18 frames opacity 30, and then 0 for 36 frames
Layer 2 - 18 frames opacity 0, 18 frames opacity 30, and 18 frames opacity 0 again
Layer 3 - 18 frames opacity 0, others 18 frames opacity 0, and then 18 frames opacity 30
I mean like three blocks of 18 frames, and each layer appears in one of this blocks.... would it be possible?
A lot of thanks!
Dan Ebberts
on Oct 24, 2015 at 10:45:42 pm
This would be one way. You'd have to edit the first line for each layer:
pattern = [30,0,0];
n = 18;
pattern[s%pattern.length]
Dan
Luis Garcia
on Oct 25, 2015 at 10:05:55 pm
Great again Dan! It seems that works perfectly. I will try it more slowly and feedback. I supousse that if I want to create a 4 group, in the first line I will put this, isn´t it?
pattern = [30,0,0,0]
And then edit for each group....that´s right?
A lot of thanks!!!
Dan Ebberts
on Oct 25, 2015 at 10:39:07 pm
That's correct.
Dan
Luis Garcia
on Oct 26, 2015 at 9:05:18 am
A lot of thanks Dan for your answer and time....
That´s a great solution for "my problem".
I am wondering one thing now... I have 21 text layers, and I want to divide them into three groups...
I have tried to create three null objets and then linking each 7 text layers to their null object, and then apply the expressions into the null objects but I hadn´t any result...
Can´t I do it? Another way to do? Could I create a group or something like this or apply the expressions to my 7 layers at the same time??
Thanks again Dan!!!
Luis Garcia
on Nov 10, 2015 at 11:26:39 pm
Hi! One Question Dan... If I precompose I lost my effect of this expression... Could I modify the expression to work with precomposing??
I am thinking to create one precompose for every 7 text layer to organize the project better, but when I have done it... I lost the effect of the expression...
Could you help me? How would be the expression with precompose?
Imagine I have 3 precompose....
Thanks in advance!
Dan Ebberts
on Nov 10, 2015 at 11:57:35 pm
What exactly are you precomposing?
Dan
Luis Garcia
on Nov 11, 2015 at 8:53:26 am
I am precomposing every 7 text layers, if I have 21 text layers, I am doing 3 precomposing with the same expressions... Yesterday, I did another prove and it worked... So I don´t know if perhaps before I will make a mistake....
Is correct to precompose with expressions and they have to work?
Dan Ebberts
on Nov 11, 2015 at 2:55:13 pm
It depends on the expression. If it doesn't reference other layers it should be fine.
Dan
