Play and Pause on markers
COW Forums : Adobe After Effects Expressions
Chris Scalzo
on Oct 21, 2015 at 5:40:43 pm
I know this should be easy, but I'm trying to write a time remap expression freeze and play based on clip markers. I am surprised i couldn't find this already made. I will post it if I figure it out.
Dan Ebberts
Re: Play and Pause on markers
on Oct 21, 2015 at 6:51:51 pm
I'm not sure what you have in mind exactly, but since expressions have no memory, your expression will need to calculate how much play time has occurred in the past by examining each marker previous to the current time.
Dan
Chris Scalzo
on Oct 21, 2015 at 7:42:23 pm
I understood this, and that is the part I'm trying to figure out. I wrote this after sending the post, but I still need to write something for calculating totaltime of the odd or even marker differences.
try{
m = thisLayer.marker;
i = m.nearestKey(time).index;
if (m.nearestKey(time).time > time){ i--;}
if (i &lt; 1) { i = 1};
if (i%2==1) {marker.key(i).time} else {totaltime}
}catch(err){0}
Dan Ebberts
on Oct 21, 2015 at 7:47:52 pm
Are the odd numbers play or pause?
Dan
Chris Scalzo
on Oct 21, 2015 at 7:50:55 pm
Currently The odd numbers are pause and I'm starting clip off frozen with marker off top.
Chris Scalzo
on Oct 21, 2015 at 7:49:41 pm
My last post didn't paste correctly. Something weird between Mac and PC text.
try{
}catch(err){0}
Dan Ebberts
on Oct 21, 2015 at 7:55:42 pm
If you're going to post code, don't preview your post, or all the < characters will get converted to html codes when you finally post it.
Dan
Chris Scalzo
on Oct 21, 2015 at 7:58:18 pm
Thanks. Was going crazy. < > test lol
Dan Ebberts
on Oct 21, 2015 at 8:43:20 pm
I think it will be something like this:
if (m.numKeys > 0){
i = 1;
segStart = 0;
accum = 0;
for (i = 1; i <= m.numKeys; i++){
if (m.key(i).time < time){
if (i%2){
accum += m.key(i).time - segStart;
segStart = null;
}else{
segStart = m.key(i).time;
}else{
break;
if (segStart != null){
accum += time - segStart;
accum;
}else
time
Dan
Chris Scalzo
on Oct 21, 2015 at 8:50:22 pm
Looks good to me. Thanks, your biggest fan (probably not, since you are a rock star).
Chris Scalzo
on Oct 21, 2015 at 10:47:41 pm
One more thing I'm trying to figure out with another expression I'm using with the previous. I wrote the following expression to toggle an Effect Opacity on and off with keyframes. I can't figure out how to use easeOut to ramp the transition from 0 to 100 and back to 0 (on following keyframe).
try{
i%2*100
}catch(err){1}
Dan Ebberts
on Oct 21, 2015 at 11:14:03 pm
This might work:
easeTime = .25;
if (m.numKeys > 0){
if (m.nearestKey(time).time > time) i--;
if (i > 0){
t = time - m.key(i).time;
if (i%2){
ease(t,0,easeTime,100,0);
}else{
ease(t,0,easeTime,0,100);
}else{
100;
}else{
100;
Dan
Chris Scalzo
on Oct 22, 2015 at 12:00:33 am
Worked perfectly. Thanks again.
