Expresion to change scale between two values....
COW Forums : Adobe After Effects Expressions
Luis Garcia
on Oct 20, 2015 at 9:37:17 am
Hi! I need to get an expresion to do that in a layer the scale value ("x" value) changes in a ramdon mode between 11% and -11% (I would like to reverse the text.... I would need that the value will be or 11% or -11% and that it will change in a random mode....
I have tried with a wiggle expression but I haven´t be able to do it... I get move the x value but I can´t get it into negative value, and therefore, it changes bit a bit.
Someone could help me??
Thanks in advance!!
Kalle Kannisto
Re: Expresion to change scale between two values....
on Oct 20, 2015 at 6:53:25 pm
I'd make a slider control set at 0 and add a wiggle expression to it. Then connect your scale property to the slider and set the scale to negative if the slider is <0 and positive if the slider is >=0.
Luis Garcia
on Oct 21, 2015 at 7:09:06 am
Great!!!!! A lot of thanks!!! I can´t prove it now, but I will prove this afternoon and tell you if it works for me. I think that this will work sure... In any case, I will prove and tell you
Thank you very, very, very much it helps me a lot!!!!
Luis Garcia
on Oct 22, 2015 at 8:45:39 am
I have tried it and works perfectly!!
A lot of thanks Kalle you are a great master!!!!!
Thanks, thanks, thanks!
