Expression for link relative position of a stroke to a track/null
COW Forums : Adobe After Effects Expressions
Gustavo Saliola
on Sep 29, 2015 at 2:52:59 pm
Hi everyone. I'm trying to solve this simple problem via expressions (not by precomping). Have this shot with handheld camera of the back of a car. In middle shot, i've made several paint strokes covering the license plate. Tracked the camera movement (a minimal x/y pan), created a null, and now i need to aply that movement to all the 12 strokes that made with the clone tool.
The catch is that i need to maintain all the 12 stroke's relative positions, not just simply parent them and get off of those original and correct positions.
I know in my guts that a simple expression exists for this task (And not being forced as i did to manually adjust every single clone stroke's position keyframes by hand to the place they were, by copy/paste the null's position).
Thanks in advance. Hope Dan is around :)
Bryan Woods
Re: Expression for link relative position of a stroke to a track/null
on Oct 2, 2015 at 1:04:39 am
I think you're better off with planar tracking the license plate and then painting on a still thats distorted to the planar tracker's output. Otherwise, to get this to work in AE I think you might need to track each individual feature you're painting out so you have positional data for that paint fix, and then apply a paint layer tied to the position value of that tracked feature.
Gustavo Saliola
on Oct 2, 2015 at 7:10:43 pm
Thanks Bryan. Normally, i use all of the methods described by you (Mocha, multiple tracks). This time is just a wish for commodity. It's so simple that i'm sure there's and expression for that. As i said earlier, a simple expression that maintains the original brush/clone position, but moves linked to a null/position.
