position a shape to the end of a text
COW Forums : Adobe After Effects Expressions
Gerg Tolcs
on Sep 23, 2015 at 3:47:48 pm
Hi, maybe it's not a real problem, I just want to ask you, maybe you have more experiences with this issue.
I'm working with text and shape layers, and don't use anything, just script files. I want to position a shape to the end of a text, position the next text to the 'end' of the shape, etc
The text is changing, and I have to count the positions again and again.
I use the sourceRectAtTime function, to find the end of the text layer, and a constant, to position the shape to the right coordinate. It's ok, but not perfect.
I realized, that the values from sourceRectAtTime are not the best for me. I made a little script (post it here, and of course, there are some exceptions :) :) ) to look how it works, an I find, that last and first characters affect the width more than the others. MAGE.width != AMGE.width, but MAGE.width == MGAE.width
Did you have what can I do - a shorter/easier way - to find the right place for my shapes in the center between two text layers, what are changing? Thank you!
var myComp = app.project.activeItem;
var abc = 'ABCDEFGHIJKLMNOPQRSTUVZ';
var myText = myComp.layers.addText('');
var textSource = myText.property("Source Text");
var output3 = '';
var word, letter1, letter2, resultNUM;
for(var i=0; i&lt;3; i++){
letter1 = abc .substr(Math.floor(Math.random()*22),1);
letter2 = abc .substr(Math.floor(Math.random()*22),1);
for (var j=0; j&lt;7; j++){
word = '';
for (var k=0; k>>
P///29.9994142726064
T///25.8761719800532
!word - word : 4.12324229255319
PB///79.7273905519396
TB///76.933347530663
!word - word : 2.79404302127659
BP///80.8260233644396
BT///74.845945186913
!word - word : 5.98007817752659
PAR///122.69540578872
TAR///119.901362767443
ARP///127.52939016372
ART///120.414058079943
!word - word : 7.11533208377659
PACK///165.150729527697
TACK///162.35668650642
ACKP///171.387155361474
ACKT///165.407077183947
PCBJB///208.33436610736
TCBJB///205.540323086083
CBJBP///207.397158971056
CBJBT///201.41708079353
PVNIBQ///259.981576748192
TVNIBQ///257.187533726916
VNIBQP///261.838412633166
VNIBQT///255.858334455639
PKJJCLP///282.672342129052
TKJJCLP///279.878299107775
KJJCLPP///282.818826504052
KJJCLPT///276.838748326525
R///30.6585939601064
M///29.9777344800532
!word - word : 0.68085948005319
RJ///59.9303201343864
MJ///65.0830544568598
!word - word : -5.15273432247341
JR///70.8800271656364
JM///72.0044411756098
!word - word : -1.12441400997341
RNK///126.529780736193
MNK///131.682515058666
NKR///125.907222142443
NKM///127.031636152416
RTLI///144.679538121447
MTLI///150.96752635017
!word - word : -6.28798822872341
TLIR///153.285495152697
TLIM///154.40990916267
RJTLV///194.067080846056
MJTLV///199.21981516853
JTLVR///201.244815221056
JTLVM///202.36922923103
RISBJR///237.056772060692
MISBJR///242.209506383166
ISBJRR///235.251498570666
ISBJRM///236.375912580639
RQFGSPB///314.690002704039
MQFGSPB///319.842737026513
QFGSPBR///316.510217495263
QFGSPBM///317.634631505236
K///28.3406251575798
Q///36.0052736476064
!word - word : -7.66464849002659
KI///58.5020974781364
QI///65.8263162281364
!word - word : -7.32421875
IK///61.2012185193598
IQ///66.9981912281364
!word - word : -5.79697270877659
KJV///106.754390111193
QJV///114.078608861193
JVK///112.602925214916
JVQ///118.399897923693
KIHM///163.576022496447
QIHM///170.900241246447
IHMK///166.27514353767
IHMQ///172.072116246447
KJLSC///190.697940221056
QJLSC///198.022158971056
JLSCK///197.31551829353
JLSCQ///203.112491002306
KUFPTU///259.567904820666
QUFPTU///266.892123570666
UFPTUK///262.230404768139
UFPTUQ///268.027377476916
KOASMTI///293.428088536486
QOASMTI///300.752307286486
OASMTIK///299.726916661486
OASMTIQ///305.523889370263
Gerg Tolcs
Re: position a shape to the end of a text
on Sep 23, 2015 at 3:49:13 pm
"The text is changing" === Source Text is changing, not position, or anything else
Kalle Kannisto
on Sep 23, 2015 at 4:06:02 pm
Sounds very complex. If you can upload a picture or two of what you are trying to achieve, perhaps there is a whole different approach someone can suggest for the problem.
Gerg Tolcs
on Sep 24, 2015 at 8:17:59 am
Maybe it will show my problem, thank you!
Kalle Kannisto
on Sep 24, 2015 at 9:02:25 am
It is not an After Effects solution, but I would make this into a font with those shapes as characters, then you could type it in as text and everything else would be pretty straightforward.
I use Fontlab's FontoGrapher but there are some free font creation programs that should do it as well:
http://mashable.com/2011/11/17/free-font-creation-tools/#TAsnSvmcZGkP
Gerg Tolcs
on Sep 24, 2015 at 9:21:12 am
Great idea, but I'm afraid, It doesn't work for me, It's a lyric video, and all the 240 words contain these two characters. The Idea, that the shape chracters stays on the screen, and the other parts of the words appear and disappear, with animation, 3d position, opacity, etc, anything, I guess, impossible make it with one textlayer/word :/
Kalle Kannisto
on Sep 24, 2015 at 9:51:36 am
I see. So you need the two shapes to smoothly move from one position to the next while the words around them change.
How about creating the words with placehold characters with suitable spacing for the shapes such as bullet and asterisk with spaces on each side (" • " and " * "), then calculating the position of just those characters and animating the position of the shapes to match the positions of the bullet and the asterisk? You wouldn't have to worry about spacing any of the characters in the words, just calculating those two locations in the consecutive words and animating the position of the shapes between them.
