Controlling color and scale with a Null's position?
COW Forums : Adobe After Effects Expressions
Simon Terrey
on Sep 21, 2015 at 3:55:09 pm
Hi everyone!
I'm making a timeline where when I move a Null, data panels attached to the timeline scale in size.
I've managed to find a script to do this (which I assign to the scale parameter of the data panels):
So when I move the Null (called Scale_Control) towards the panels the panels grow! Great. But what I want to do as well is change their color as they grow in size and go back to their original color when the Null has passed-on. I've looked everywhere and know I need to convert the colors to HLS with an array (I think) and use a similar approach to the scale expression above but I can't get it to work.
Hope you can help?
mouse_layer = thisComp.layer("Scale_Control");//Mouse layer
beginScale = 75;//Scale begins at this
endScale = 100;//Scale ends at this
beginDistance = 200;//Distance to begin magnifying in pixels
endDistance = 0;//Distance to end magnifying in pixels
//--Don't modify below here
dis = length(this.position, mouse_layer.position);
val = ease(dis, beginDistance, endDistance, endScale, beginScale);
[val, val]
Dan Ebberts
Re: Controlling color and scale with a Null's position?
on Sep 21, 2015 at 4:24:03 pm
You didn't mention exactly what you want the color to do.
Dan
Simon Terrey
on Sep 21, 2015 at 4:26:22 pm
Hi Dan,
I just wanted it to change from grey to orange as it scales-up, then go back to grey when it scales back-down again.
Dan Ebberts
on Sep 21, 2015 at 4:37:46 pm
If you applied a Fill effect you could use something like this on the Color parameter:
beginColor = [.5,.5,.5,1]; // grey
endColor = [1,.5,0,1]; // orange
ease(dis, beginDistance, endDistance, endColor, beginColor);
Dan
Simon Terrey
on Sep 21, 2015 at 4:45:56 pm
Hi Dan,
Many thanks for getting back to me with this!
I've just tried it on the Fill layer (of my shape layer) and it returned with this:
Error at line 0 in property 'Color' of layer 15 ('DataPanel 11') in comp 'Timeline'.
Object of type Layer found where a Number, Array, or Property is needed.
This was the message that flagged-up when I tired other techniques earlier...
Dan Ebberts
on Sep 21, 2015 at 5:00:01 pm
I hadn't tried it on a shape layer (I was using a solid with the Fill effect), but it seems to work fine for me (with a shape layer, the anchor point will need to be at the center of the shape). The only way I can generate your error message is to leave out everything except the first line.
Dan
Simon Terrey
on Sep 21, 2015 at 5:17:21 pm
Hi Dan,
I've just tried uploading a small comp aep file with my controller Null and a shape layer (and a new solid with fill) to show you what i'm doing.
I tried your expression on a new Solid with a fill and it flagged the same error message!
Are expressions different between CC versions by any chance?
Simon
Simon Terrey
on Sep 21, 2015 at 5:24:46 pm
Hold the fort!
I've got it working. When I paste the expression in, it goes in on one line.
As soon as I added returns at the end of each line to match-up with the original the error message went away and it's all good!
Dan the Man!
Thank you very much.
Simon
