Multiple text sources from multiple markers on the same layer
COW Forums : Adobe After Effects Expressions
Craig Kristensen
on Sep 14, 2015 at 4:12:19 pm
I have 4 seperate text layers which I am trying to control from a single layer.
I can update the text by using a marker on every layer, but I need to be able to place 4 markers on a different layer and then update the 4 seperate text layers from them.
Any ideas on how to approach this?
Dan Ebberts
Re: Multiple text sources from multiple markers on the same layer
on Sep 14, 2015 at 7:48:47 pm
The text layer expression would need to be able to identify which marker to reference. If the text layers are layers 1 through 4, you could do it like this:
thisComp.layer("controls").marker.key(index).comment
Dan
Craig Kristensen
on Sep 14, 2015 at 8:25:31 pm
That worked like a charm!
You're a superstar Dan!
Kalle Kannisto
on Sep 14, 2015 at 8:28:43 pm
Unless you specifically want to use markers, you could also keyframe the Source Text value on one layer and then link the others to it.
