check if property is active
COW Forums : Adobe After Effects Expressions
Hernan Torrisi
on Sep 11, 2015 at 2:04:08 am
I'm trying to determine if a text has an ADBE Text Stroke Color applied to it.
In this cases I usually check for the isModified attribute to see if the default value has changed.
But in this case, when the property is active and the value is not modified, I get false on isModified but the red stroke is applied nevertheless.
Any idea how to check if Animators are applied or not to text elements?
thanks!
Xavier Gomez
Re: check if property is active
on Sep 11, 2015 at 6:23:44 am
In this case, p.canSetExpression should work.
(If true the property is visible and can be modified, else it is not activated).
Xavier.
Hernan Torrisi
on Sep 11, 2015 at 10:02:00 am
great
thanks!
