Converting speed into pace and expressing it correctly
COW Forums : Adobe After Effects Expressions
Chris Craig
on Aug 11, 2015 at 10:14:17 am
Hi everyone
Please can someone help me with an expression.
I would like to convert speed (km/hr or miles/hr) into pace (min/km or min/mile).
To do this, I need to divide 60 by the speed and then express the fractions as a time.
For example my text layer named "Pace" is currently 5.67 km/hr.
To calculate the pace it would be 60 / Pace layer (5.67) = 10.58
Then i need to convert the .58 into seconds
Thanks very much
Chris
Xavier Gomez
Re: Converting speed into pace and expressing it correctly
on Aug 11, 2015 at 12:49:42 pm
Once you get your pace as decimal number in min/km, to decompose it in min:sec, you can do
min = Math.floor(pace);
sec = (pace-min)*60;
This gives the seconds part as a decimal number.
If you want a plain integer for the seconds, replace the second line by:
sec = Math.round((pace-min)*60);
Xavier
Chris Craig
on Aug 11, 2015 at 11:20:22 pm
Thanks Xavier for your reply.
Would this be the full expression or just the decimal to seconds? I have pasted what you have given me, but as Im rusty with expressions, Im not sure how to write the entire expression.
Thanks a lot
Xavier Gomez
on Aug 12, 2015 at 9:15:32 am
Ah ok, i started where you had troubles.
Full expression:
// x : input speed (unit distance/hour)
x = 5.67;
// pace in min / unit distance
pace = 60/x;
// decompose min:sec
if (sec===60){sec=0; ++min;};
// display text :
"pace : " + min + " minutes " + sec + " seconds per unit distance";
Chris Craig
on Aug 12, 2015 at 10:31:37 pm
Thank you so much Xavier.
I have tried this and am coming across a slight issue. The Pace value that this expression is converting from, is a random expression on a separate layer. I thought i would be able to pick whip the "source text" of this layer and plug it in to your expression, but it appears that I can not not do that.
Would you know how i can get the expressed value of another layer and plug it into your expression?
Thanks again for your help in this.
Xavier Gomez
on Aug 13, 2015 at 12:52:42 am
You'd have to parse the speed text and extract the number, the way to do it depends on how the text looks like.
I think it would be a bit easier if the speed value was carried by a slider (with your random expression on it), and then collected (=pickwhipped) by both text layers (the speed and the pace one).
In the speed text:
x = effect("Slider Control")("Slider").value;
"Speed : " + x + "km/h";
And in the pace text, the expression from the previous post with x taking the slider value.
Xavier
