Layer Change through Expression Controls ..? and also including layer on/off..?
COW Forums : Adobe After Effects Expressions
Suniel Surya
on Jun 16, 2015 at 8:14:24 am
ok.. I'm Creating a Template For Our local Tv...It's just like on Lower Third... but actually it's local ad
we are using 3 positions (left,Right,Bottom) and we never used 3 positions at a time...
for that... i created 3 solids and name as left,right,bottom
then i created a adjustment layer and applied layer control expression... and check box expression control
how can i link my solids to expressions...
actually what i need is if i select bottom in layer control that solid (bottom) will show
and if i select right in expression control then right solid will show and other two layers will hide...
and some i don't need 3 solids expect the logo layer.. for that situations i applied checkbox control .. if i check on checkbox control one of the three layers will show ( Based on my layer Control Expression).. if i un check all 3 layers will disable
please check below images for more details :-
i'm using this code for checkbox control expression for on/off the layer :-
if(thisComp.layer("Controls").effect("Layer On/ Off")("Checkbox") ==0) 0 else 100;
but this expression on /off the all layers... but i need if i check on checkbox control and then i select which layer will show from layer control expression
P.Surya Suniel
© 2018 All Rights Reserved
