Break a time remap expression
COW Forums : Adobe After Effects Expressions
Milos Milunovic
on May 22, 2015 at 11:06:05 am
Hi people, another rookie in expressions.
here is my problem:
I have a composition with time remap and a expression:
state=comp("comp_1").layer("character").effect("outfit")("ADBE Slider Control-0001");
framesToTime(state);
Null with a slider that is controlling a time remap.
I wont to break expression with a checkbox and be able to controll the compositions frame number with another null and a slider.
My humble opinion is to use if/else command.
I managed to do similarly with this exspression:
effect("default")("Slider")
if (effect("dafault_character_on/off")("Checkbox").value)
{effect("default")("Slider")
}else
value
in general I need to break a time remap expression (that is controll by a slider) with checkbox and use another slider to control the same composition.
Thanks in advance.
Dan Ebberts
Re: Break a time remap expression
on May 22, 2015 at 5:03:25 pm
I haven't tested it, but I guess it would be like this:
if (effect("dafault_character_on/off")("Checkbox").value){
}else{
state=comp("comp_1").layer("other null").effect("other slider")("ADBE Slider Control-0001");
Dan
Milos Milunovic
on May 22, 2015 at 6:56:07 pm
Dan, thank You for replay.
I will try it.
works perfectly!
thanks
Dan,
is it possible to pick whip both way two sliders? if I type a number 12 in one the other change to 12 and the other way if I type in second slider some value the first slider change to that value.
Is there an expression for that?
I try to pickwhip-it and I get some funky results.
Thanks.
Milos Milunovic
on May 25, 2015 at 12:43:07 pm
Works perfectly.
Thanks again.
Milos Milunovic
on May 25, 2015 at 2:47:00 pm
Dan,
Thanks.
Dan Ebberts
on May 25, 2015 at 3:53:15 pm
Setting up two expressions so that each depends on the other for its result will give you unpredictable results. Don't do it.
Dan
