Using Layer control to select particular layers.
COW Forums : Adobe After Effects Expressions
Justin Maloney
on Mar 30, 2015 at 3:30:27 pm
Hey there, I'm trying to make a Layer Control box that can switch which layers are visible (say flip the selected layer's opacity from "0" to "100")
I'm also trying to control the layers in a pre-comp, from a master comp.
For example:
I have a Master Comp with a Pre-Comp imbedded. And a Null object (named "Shape Selector") with the layer control.
Inside the Pre-comp, I have the layers I'd like to switch between. ("Circle", "Square", and "Triangle")
Is an expression that lets me switch between the shape layers in the pre-comp, from the Master Comp, even possible?
Thanks very much in advance =D
Dan Ebberts
Re: Using Layer control to select particular layers.
on Mar 30, 2015 at 4:27:12 pm
The layer control dropdown only lists the layers in the comp with the control, so it wouldn't work across comps.
Dan
Dan Ebberts
on Mar 30, 2015 at 6:05:58 pm
I think the best you could do is maybe use a slider control in the Master Comp and then use an expression like this on the opacity of the shapes in the pre-comp:
if (Math.round(comp("Master Comp").layer("Shape Selector").effect("Slider Control")("Slider")) == index) 100 else 0
Dan
Justin Maloney
on Mar 31, 2015 at 8:09:53 pm
That could work. But the other animators I'm making this for would be thrown for a loop for with a control like that. It was for a character rig I'm building. I wanted to make it so they could easily select a different hair style, nose style, wardrobe, etc, with drop down boxes. I stuck with check box controls for each option.
thisComp.layer("Hair Styles").effect("Emo Swoosh")("Checkbox") *100
But I'll keep what you showed me in mind for other things =D
