Custum UI button onClick don't work???
COW Forums : Adobe After Effects Expressions
Taras Kosmachuk
on Mar 29, 2015 at 11:41:27 pm
Hi! Can someone help me to solve my problem, please!
The problem is that when I run my script it executes functions assigned to buttons all at once and then all buttons except "Button 3" with alert stop working. Why is this happening?
Thanks in advance!
// Global Variables
var _comp = app.project.activeItem;
{ // Build UI
function UI(thisObj){
function buildUI(thisObj){
var uiPanel = (thisObj instanceof Panel) ? thisObj : new Window("palette", "new project", undefined, {resizeable:true});
var res = "group{ orientation: 'column', \
group1: Group { orientation: 'column', \
bt1: Button{ text: 'Button 1' }, \
group2: Panel { text: 'Panel', orientation: 'column', alignChildren: ['fill', 'fill'], margins: ['20', '15', '20', '15'], spacing: '10', \
bt2: Button{ text: 'Button 2', preferredSize: ['150', '30'] }, \
bt3: Button{ text: 'Button 3', preferredSize: ['-1', '30'] }, \
bt4: Button{ text: 'Null', preferredSize: ['-1', '20'] }, \
stName: StaticText{ text:'Name:', alignment: ['left', 'center'] }, \
etName: EditText{}, \
bt5: Button{ text: 'Button 5', preferredSize: ['-1', '20'] }, \
uiPanel.grp = uiPanel.add(res);
// Declare functions for Buttons
var BT1 = uiPanel.grp.group1.bt1;
var BT2 = uiPanel.grp.group2.bt2;
var BT3 = uiPanel.grp.group2.bt3;
var BT5 = uiPanel.grp.group2.bt5;
BT1.onClick = f1();
BT2.onClick = f2();
BT3.onClick = function() { alert(":)"); };
BT5.onClick = f3();
// Setup size and resizing
uiPanel.layout.layout(true);
uiPanel.grp.minimumSize = uiPanel.grp.size;
uiPanel.layout.resize();
uiPanel.onResizing = uiPanel.onResize = function() { this.layout.resize(); };
return uiPanel;
var scriptUI = buildUI(thisObj);
if ((scriptUI |= null) && (scriptUI instanceof Window)){
scriptUI.center();
scriptUI.show();
UI(this);
function f3() {
var numL = _comp.numLayers;
app.beginUndoGroup("03");
for (i = 1; i &lt;= numL; i++) {
_comp.layer(i).inPoint = 0;
_comp.layer(i).outPoint = 1;
_comp.layer(i).startTime = i - 1;
app.endUndoGroup();
function f2() {
app.beginUndoGroup("b2");
var sLayers = _comp.selectedLayers;
for (s = 1; s &lt;= sLayers.length; s++) {
var dLayer = sLayers[s - 1].duplicate();
app.endUndoGroup();
function f1() {
app.beginUndoGroup("b1");
var newL = _comp.layers.addNull();
newL.name = "New Layer";
app.endUndoGroup();
