puppet pins (or Nulls), bind 2 maskpoint (or shape-vertex)
COW Forums : Adobe After Effects Expressions
Baba Luba
on Mar 25, 2015 at 9:07:32 pm
Hi!
I want to animate a character and looked through the internet and found crazy talk animator
now i thought how to do that in after effects...
so my Idea would be:
binding puppet pins to mask or shape vertexes...
I know, there are techniques with Null objects, but shapes would be much better to work with
now I'm a real Null in programming, but has anyone an idea, if this is do-able / possible.
does anyone know a way
I found some cool techniques, it's cool but....
https://vimeo.com/48020641
https://vimeo.com/81750455
thanks
Dan Ebberts
Re: puppet pins (or Nulls), bind 2 maskpoint (or shape-vertex)
on Mar 25, 2015 at 11:16:17 pm
The problem is that an expression can't link to a path vertex. You can match the positions with a script, but it's not a live link (if you make changes to the vertex positions, you have to run the script again).
Dan
