encrypted expressions
COW Forums : Adobe After Effects Expressions
Adam levine
on Mar 12, 2015 at 6:09:58 pm
How can we write a encrypted expressions in AE?
Dan Ebberts
Re: encrypted expressions
on Mar 12, 2015 at 7:07:21 pm
You can use the ExtendScript Toolkit to export your expression as a .jsxbin file. You can take the contents of that file, wrap it in double quotes and stick it in an eval() function like this:
eval("@JSXBIN.....");
My experience though is that doing this can incur a significant performance penalty.
Dan
Adam levine
on Mar 12, 2015 at 8:34:23 pm
thanks Dan.. But it didn't work....
Dan Ebberts
on Mar 12, 2015 at 8:49:24 pm
It's hard to say what's going on without seeing the original expression, the .jsxbin code and the error message (if any). Is it a long expression? You may be running into and issue with carriage returns.
As a simple test, start with this:
wiggle(1,100);
Running it through the binary exporter gives this:
@JSXBIN@ES@2.0@MyBbyBn0ABJAnAEjzGjXjJjHjHjMjFBfRCFdBFdjEff0DzACByB
and this expression does in fact produce a wiggle:
eval("@JSXBIN@ES@2.0@MyBbyBn0ABJAnAEjzGjXjJjHjHjMjFBfRCFdBFdjEff0DzACByB");
Dan
Adam levine
on Mar 12, 2015 at 9:10:25 pm
thank you so much Dan.. Now I got it.. :D
Arun Chaudhary
on Jan 26, 2017 at 9:52:43 am
Hi Dan Ebberts This method do not work when expressions control by slider kindly help
Dan Ebberts
on Jan 26, 2017 at 2:15:35 pm
What are the symptoms? Are you sure it's the slider causing the problem? Any error message?
Dan
Arun Chaudhary
on Jan 26, 2017 at 5:04:47 pm
like this
http://i.imgur.com/O30OzZe.png
Dan Ebberts
on Jan 26, 2017 at 5:08:24 pm
What does the actual expression look like?
Dan
Arun Chaudhary
on Jan 27, 2017 at 5:10:58 am
Before
wiggle(effect("Slider Control")("Slider"),effect("Slider Control 2")("Slider"));
After
eval("@JSXBIN@ES@2.0@MyBbyBn0ABJAnAEjzGjXjJjHjHjMjFBfRCEEjzGjFjGjGjFjDjUCfRBFeOiTjMjJj
EjFjShAiDjPjOjUjSjPjMffRBFeGiTjMjJjEjFjSffEEjCfRBFeQiTjMjJjEjFjShAiDjPjOjUjSjPj
MhAhSffRBFeGiTjMjJjEjFjSffff0DzADByB");
Error, after effects warning unterminated string constant expression disabled
Click on image zoom it, text one show before bin & second text show after convert JSXBIN in image
Dan Ebberts
on Jan 27, 2017 at 6:41:38 am
I think it works if you get rid of the line breaks:
eval("@JSXBIN@ES@2.0@MyBbyBn0ABJAnAEjzGjXjJjHjHjMjFBfRCEEjzGjFjGjGjFjDjUCfRBFeOiTjMjJjEjFjShAiDjPjOjUjSjPjMffRBFeGiTjMjJjEjFjSffEEjCfRBFeQiTjMjJjEjFjShAiDjPjOjUjSjPjMhAhSffRBFeGiTjMjJjEjFjSffff0DzADByB")
Arun Chaudhary
on Jan 27, 2017 at 8:35:10 am
Hi Den
wow your expressions work perfectly as all time
I'm new to expressions kindly explain how to get rid of the line breaks it is very important for me
Thanks, you are hero
Arun Chaudhary
on Jan 27, 2017 at 5:27:18 pm
Den kindly reply, how can I do this
Thank you
Dan Ebberts
on Jan 27, 2017 at 5:30:21 pm
Put the cursor at the end of the first line and hit delete so the next line moves up, eliminating the break between those two lines. Repeat until the entire expression is on one line.
Dan
Arun Chaudhary
on Jan 27, 2017 at 5:57:42 pm
This is wow wow Ohh Ohh my God
Den you saved my life
actually, I check every 10 minutes for your reply before I know where Den reply my problem solved
I'm now 😃😃😃😃😃😃😃
Thank you so much Den You are my hero
Mahmoud Elsafy
on Dec 16, 2017 at 8:28:00 pm
Is there a function that converts a text to binary instead of doing it manually in ExtendScript?
