Three checkboxes
COW Forums : Adobe After Effects Expressions
Zura Bezhanishvili
Three checkboxes
on Mar 8, 2015 at 3:03:07 am
I'm newbie here and i need some help
i have a three checkboxes and i need expression which can automatically disable two of them, when one of them is turned on.
Detailed: if i turn on the first checkbox then the other two should be automatically disabled and etc...
Is it possible?
Dan Ebberts
Re: Three checkboxes
on Mar 8, 2015 at 7:20:16 am
I don't believe it can be done in a reliable way. Each of the three expressions feeds into the other two and I don't think you can set it up so that it will work correctly in all situations.
Kevin Camp
on Mar 9, 2015 at 8:12:45 pm
i've had some success by adding an addition slider control and using that to hold a value that would be used to help control the checkboxes...
try adding a slider to the same layer as your checkboxes, and manually set the value to 4 (or a value higher than the number of checkbox controls -- for some reason this seems to make it work). then add an expression like this to the slider value (set checkbox names as needed for your setup):
if ( effect("Checkbox Control")("Checkbox") == true ) 0;
else if ( effect("Checkbox Control 2")("Checkbox") == true ) 1;
else if ( effect("Checkbox Control 3")("Checkbox") == true ) 2;
else 0;
then use an expression like this on the first checkbox:
if ( effect("Slider Control")("Slider") == 0 ) true else false;
and the second:
if ( effect("Slider Control")("Slider") == 1 ) true else false;
and the third:
if ( effect("Slider Control")("Slider") == 3 ) true else false;
i put the slider at the bottom of the effects stack, but i'm not sure that matters.
Kevin Camp
Art Director
Chris Scalzo
on Mar 16, 2015 at 7:17:35 pm
Depending on what you are switching, you can create a precomp with solids labeled for choices and read the results of a layer control. Then you'd only get one of your three choices.
As an example, I made a precomp named "Pre-comp 1" and three layers named "OPT-1","OPT-2" and "OPT-3".
With the following expression I can return the value 1, 2 or 3 to change whatever else.
if (comp("Pre-comp 1").layer("OPT-1").effect("Layer Control")("Layer") == comp("Pre-comp 1").layer("OPT-1")){1};
if (comp("Pre-comp 1").layer("OPT-1").effect("Layer Control")("Layer") == comp("Pre-comp 1").layer("OPT-2")){2};
if (comp("Pre-comp 1").layer("OPT-1").effect("Layer Control")("Layer") == comp("Pre-comp 1").layer("OPT-3")){3};
© 2018 All Rights Reserved
