counter duration between two markers
COW Forums : Adobe After Effects Expressions
Adam levine
on Feb 18, 2015 at 7:50:46 am
pls!!! I need help... i need to modify this expression "duration" ("dur") to duration between two markers duration.. sorry for my English...
That mean I need to count this counter from first marker to next marker....
(I need to modify 6th row "dur" for that)
can anyone give me suggestions...
pls help... Thank you...
numDecimals = 0;
commas = true;
dollarSign = false;
beginCount = comp("Credits").layer("Lower Third Controller").effect("Begin Count Number")(1);
endCount = comp("Credits").layer("Lower Third Controller").effect("End Count Number")(1);
dur = comp("Credits").layer("Lower Third Controller").effect("Counter Duration")(1);
t = time - inPoint;
s = linear (t, 0, dur, beginCount, endCount).toFixed(numDecimals);
prefix = "";
if (s[0] == "-"){
prefix = "-";
s = s.substr(1);
if(dollarSign) prefix += "$";
if (commas){
decimals = "";
if (numDecimals > 0){
decimals = s.substr(-(numDecimals + 1));
s = s.substr(0,s.length - (numDecimals + 1));
outStr = s.substr(-s.length, (s.length-1)%3 +1);
for (i = Math.floor((s.length-1)/3); i > 0; i--){
outStr += "," + s.substr(-i*3,3);
prefix + outStr + decimals;
}else{
prefix + s;
Dan Ebberts
Re: counter duration between two markers
on Feb 18, 2015 at 5:35:43 pm
If I understand what you're trying to do, I think you can just change this line:
to this:
s = linear (time, marker.key(1).time, marker.key(2).time, beginCount, endCount).toFixed(numDecimals);
You should then also be able to delete the lines that define "dur" and "t".
Dan
Adam levine
on Feb 18, 2015 at 5:52:27 pm
Thank you so much Master Dan Ebberts.... It's totally work ...thank you again... :D :)
