Banking expression
COW Forums : Adobe After Effects Expressions
ole sturm
Banking expression
on Feb 8, 2015 at 3:13:33 am
I'm working on a sequence which requires a layer (in the shape of an arrow) to move around the screen randomly (for which I've used the wiggle expression). However, I need the layer to align along the direction that it is travelling. For example, if the layer is travelling left to right, the arrow should be pointing right. Then, when the layer changes direction, the arrow should rotate to match.
Any help would be very appreciated.
Many thanks.
Bob Wera
Re: Banking expression
on Feb 8, 2015 at 1:35:58 pm
Forgive me if I am wrong, but I believe the plugin Motion 2 has a feature like this.
Jason Jantzen
on Feb 8, 2015 at 4:15:56 pm
you need to select align layer to path. Shift alt O is the shortcut for that.
Jason Jantzen
vimeo.com/jasonj
Jason Jantzen
on Feb 8, 2015 at 5:01:50 pm
Sorry, I think that's actually ctrl alt O. I never remember that one correctly because one of the other is the open Bridge shortcut.
Jason Jantzen
vimeo.com/jasonj
ole sturm
on Feb 8, 2015 at 10:04:32 pm
Oh dear, feeling a bit thick here. Completely didn't think about that option. Thanks guys.
