Multiple number counters and gaps
COW Forums : Adobe After Effects Expressions
Ian Ellerby
on Jan 22, 2015 at 5:54:56 pm
Hi, if anybody who could help me please
I have to create a sequence of 10,000 frames (comp size 1080x1080), first frame will be full of 1's, as in
1 1 1 1 1 1 1 1 1 1 1 1 1 1
1 1 1 1 1 1 1 1 1 1 1 1 1 1 etc to fill the whole frame. (So that's 1 gap 1 gap 1 gap 1 etc)
Next frame will be full of 2's
2 2 2 2 2 2 2 2 2 2 2 2 2 2
2 2 2 2 2 2 2 2 2 2 2 2 2 2 etc
etc etc all the way up to 10,000.
I can see how using an expression from Dan Ebberts (thanks Dan) I can take one number layer and go from 1-10000 in however many seconds I need, but that's just one number, and not many over a whole frame. If I repeat that number sequence to it's right, the gap between them increases or decreases as the numbers change size. The gap needs to be consistent between each number.
Can anybody help me here please?
Thanks in advance
Ian
Ian Ellerby
Re: Multiple number counters and gaps
on Jan 27, 2015 at 11:04:39 am
Hi
In the end I added two CC RepeTile effects, and was able to repeat the counter and create the gaps between them all.
Ian
