Can I increase the interpolation amount in my path?
COW Forums : Adobe After Effects Expressions
Clint Farmer
on Jan 19, 2015 at 1:17:34 am
I am making a simple particle animation by creating a path and then copying that [path]'s Mask Path into the particle's Producer. This gives me an easy way to animate my particle, however the interpolation of the path is horrible. You can clearly see the edges and it isn't as smooth as desired. Is there any way to increase this interpolation and make my edge smoother?
Below is an example of the line that is currently created.
