script the value of Position of an Animator in a text layer
COW Forums : Adobe After Effects Expressions
Pascal Hage
on Nov 12, 2014 at 8:06:44 pm
Hi guys,
Here is a challenge for me, and I hope an easy thing for others... I would like to set the value of the Position property of an Animator in a text layer.
Just not to confuse anybody, it's not the Position property in the Transform section I am targeting but really the one in an Animator.
I have to use a script as I am using the sourceRectAtTime() function to identify the width for the text layer.
Any help would be greatly appreciated.
PH
Dan Ebberts
Re: script the value of Position of an Animator in a text layer
on Nov 12, 2014 at 8:36:09 pm
Something like this should work:
var myLayer = app.project.activeItem.layer(1);
var myProp = myLayer.property("Text").property("Animators").property("Animator 1").property("Properties").property("Position");
myProp.setValue([50,50])
Dan
Pascal Hage
on Nov 13, 2014 at 3:21:29 pm
Wow! You're a star, this is exactly what I needed!
Actually, I was missing the two extra property ("Animator") and ("Properties")...
Thanks Dan
