Position/scale backslide first keyframe
COW Forums : Adobe After Effects Expressions
Jim Hartnett
on Nov 7, 2014 at 4:54:28 pm
I'm trying to do sort of an inertial bounce in reverse. I'm sliding a logo on the X-axis. I would like it to slide back slightly on the 1st key-frame before it moves to the 2nd. Sort of like taking a step back before jumping forward. Any ideas??
John Gardner
Re: Position/scale backslide first keyframe
on Apr 14, 2017 at 12:11:36 am
Hi Jim,
Did you ever find a solution to your question? I happen to be looking for a similar expression, so I'm curious if you found anything.
John
Steve Sierra
on Apr 27, 2017 at 3:33:47 pm
I think this works if you put it in the x Position of your layer (seperate dimensions first) :
var Speed = 50;
var backUpAmount =300;
if(time<6/Speed ){
Math.cos(time*Speed )*backUpAmount;
}else{
time*Speed*backUpAmount - 5*backUpAmount;
I'm not sure why "6" and "5" work, but they seem to.... Must have something to do with the time cos takes to do a cycle...
Hope this helps 😉
Cheers !
John Gardner
on May 2, 2017 at 7:01:51 pm
Thanks Steve!
