Layer In-Point based on Null x-position
COW Forums : Adobe After Effects Expressions
Cory Cullington
on Oct 7, 2014 at 5:58:53 pm
I'm hoping that I can get a bit of advice for the animation I'm trying to script.
A bit of background info:
I have a map of the US that has potentially hundreds of pins spread across it. These pins are each instances of a small video (150x250 pixels) rendered out with an alpha channel so that they begin to scale up from 0% at t=0 and then sit at their final scale for the rest of the animation.
What I was hoping to achieve is, in essence, "the wave" from screen left to right, based on the x-position of a null object. As the null passes the x-positions of the pin layers, the layers would begin playing from t=0.
So I suppose what I would be altering would be each layer's in-point, and I would be placing this expression on each pin layer.
I hope the description is clear enough. Thank you for any / all advice! =)
Cory Cullington
Re: Layer In-Point based on Null x-position
on Oct 7, 2014 at 7:09:31 pm
Update: The expression that I have right now is operation on the Time Remap property of my pin.
The null object passes the xPos of the pin at 3:14, at which point the pin layer jumps to a Time Remapped position of 3:14. I tried adding in timeRemap-time, but because the time value constantly updates, that results in a value of 0:00:00:00.
Is there any way to start the Time Remap fresh from 0 as soon as else is triggered?
if (thisComp.layer("Null 1").transform.xPosition<transform.xPosition) {
time=0
}else{
timeRemap
Dan Ebberts
on Oct 8, 2014 at 12:12:18 am
Triggers can be tricky beasts. This should be close to what you're looking for though:
P = thisComp.layer("Null 1").transform.xPosition;
threshold = transform.xPosition;
trig = false;
for (f = timeToFrames(time); f >= 0; f--){
tCur = framesToTime(f);
v = P.valueAtTime(tCur);
if (trig && (v < threshold)) break;
if (v >= threshold) trig = true;
t = trig ? time - framesToTime(f+1) : 0;
Dan
Cory Cullington
on Oct 8, 2014 at 12:22:29 am
Thanks so much, Dan! Was exactly what I was looking for. Would it be possible for you to make a few notations on what the lines are accomplishing for me?
