Can't Reference Layers of Parent Comp with Expression in CC 2014
COW Forums : Adobe After Effects Expressions
Kevin Burke
on Sep 26, 2014 at 5:56:22 pm
I'm getting an error when I pickwhip to reference a layer in the parent comp of my layer with the expression.
This does not make any sense to me...if I pickwhip, the layer name should be correct. Does anyone know what might be happening? Thank you.
Kevin Camp
Re: Can't Reference Layers of Parent Comp with Expression in CC 2014
on Sep 26, 2014 at 7:15:38 pm
it should work that way. double check that you have the latest update.
if so, you might try a reboot and see if that has any effect.
if that doesn't help, file a bug report by either choosing help>send feed back, or use this link:
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Quba Michalski
on Oct 6, 2014 at 9:37:58 pm
Is it at all possible that you have more than one composition called "grid" ? Just a wild guess, as the error, indeed, does not make sense.
Quba Michalski
qubahq.com
