How link Rotation to different comp?
COW Forums : Adobe After Effects Expressions
Ben Peterson
on Aug 17, 2014 at 10:07:00 am
I need to control the y rotation of my layer from a different comp. I have tried pick wicking to an angle control in other comp and the controller works until I try to keyframe it. I also tried linking to YRot of a null but again I cannot seem to keyframe the movement.
Is there a way to do this. It seems like a very basic thing but I have tried and failed. Can someone please explain in layman's terms how I do this. I know I have to pickwick etc but why is the movement unable to keyframe?
Dan Ebberts
Re: How link Rotation to different comp?
on Aug 17, 2014 at 5:06:02 pm
This happens if the nested comp layer has been moved in time so that it doesn't start at time = 0. You need to compensate for that by modifying your rotation expression to something like this:
C = comp("Main Comp");
ctrl = C.layer("controls").effect("Angle Control")("Angle");
L = C.layer(;
© 2018 All Rights Reserved
