68 layers with expression - slows down. Optimization possible?
COW Forums : Adobe After Effects Expressions
Anders Hattne
on Aug 14, 2014 at 9:52:26 am
I have made the following expression which runs a short (3 second) animation from a different composition once the CTI hits a marker that corresponds to its layer's name: So layers named "1" start when they hit marker 1, layers called "2" at marker 2 and so on.
This is also applied to the scale property, on 68 layers (and might be applied to 130 layers in the end).
At some point the comp gets a bit slow. I wonder if it could be because of the expression - since "timeAdvance" goes on counting once it has hit it's marker.
Is there a way to make the expression stop doing anything once it has done its three seconds of work?
Or are these expression not really processor heavy? Or is it the 68 layers?
//reference COMP for animation
srcLayer= comp("main animation 1").layer("animation 1");
lNme =; //the name of this layer
val1 = lNme.substr(0, 1); // first letter decides TIMING
//the time of marker corresponding to the layer name
compMarkerTime = thisComp.marker.key(val1).time;
if (compMarkerTime <= time){
timeAdvance = (time - compMarkerTime);
} else {
timeAdvance = 0;
© 2018 All Rights Reserved
