Expression to make only one of several layers in a pre comp visible
COW Forums : Adobe After Effects Expressions
Brian Speight
on Jul 21, 2014 at 7:17:08 pm
I'm an expression newbie and this forum has been invaluable. Unfortunately, I haven't found an answer for my issue below:
Basically, I have a pre comp with 3 layers that is being controlled by a null in my main composition. I only want to be able to see 1 of the 3 layers at any particular time and I'd like to be able to control which of the 3 is visible from my main comp via the null.
Ideally, it would be something like the layer control where I would have a drop down with the 3 layers listed. I could then choose the layer I want to be visible and have that generate the keyframe.
I've seen how to do this with 2 layers in the pre comp via the slider control but I can't see how to adapt that to choosing between 3 layers.
Dan Ebberts
Re: Expression to make only one of several layers in a pre comp visible
on Jul 21, 2014 at 7:32:33 pm
You can use a slider control like this:
s = comp("Main Comp").layer("controls").effect("Slider Control")("Slider");
(Math.round(s) == index) ? 100 : 0
If the slider control value rounds off to 1, layer 1 will be visible, etc.
Dan
Brian Speight
on Jul 21, 2014 at 7:57:40 pm
Perfect!
That is going to really help me to simplify this prototype.
Thanks very much!
Brian
