Bounce 3D layer at specific time
COW Forums : Adobe After Effects Expressions
Erik Lingerfelt
on Jul 20, 2014 at 4:09:57 pm
Hello Dan, everybody...
It's been a while since I've been here...
So, I've searched all over and tried several expressions to do what I want, but it just doesn't work.
I got Dan's Bounce with (his also) timeToStart I found around here, but the layer it's attached to (position) won't budge.
I trie using the inPoint option also, and dragging the layer to show at 2 seconds - for which I removed all the "time" options, leaving only the raw Bounce expression... and still it doesn't move. What I notice is that the expression starts over at 0 and by the time it get's to 2 seconds, THEN I see a little movement.
I hope I was clear on this.
What can I do ?
Thanks.
Erik
timeToStart = 2;
t = time - timeToStart;
if (t > 0){
veloc = 10;
amplitude = 700;
decay = 5.0;
y = amplitude*Math.cos(veloc*time)/Math.exp(decay*time);
value + [0,y,0]
}else
value;
Dan Ebberts
Re: Bounce 3D layer at specific time
on Jul 20, 2014 at 4:33:22 pm
Try changing this line:
to this:
y = amplitude*Math.cos(veloc*t)/Math.exp(decay*t);
Dan
Erik Lingerfelt
on Jul 20, 2014 at 4:42:53 pm
Hummmmm, yes! Thanks Dan!
That worked for the bounce at set time.
Now, as predicted, I need the layer to stay off screen until the bounce kicks in.
I tried setting the last line to a value offscreen, but didn't work.... :(
Erik
Dan Ebberts
on Jul 20, 2014 at 5:40:04 pm
Does the starting/maximum amplitude value put it off screen? If so, this should be all you need:
timeToStart = 2;
t = Math.max(time - timeToStart,0);
veloc = 10;
amplitude = 700;
decay = 5.0;
value + [0,y,0]
Dan
Erik Lingerfelt
on Jul 20, 2014 at 5:43:05 pm
Yes, indeed!
What a cleanup in the code, huh ? :) NICE!
All I needed was the timetostart line...
Thanks a lot, Dan. You ARE the one! :D
Erik
