Expressions and contents problem
COW Forums : Adobe After Effects Expressions
Diego Mellado
on Jun 4, 2014 at 3:32:55 pm
Hello!
First of all, thanks for your attention. I am having trouble with the following expressions.
Whilie this works OK:
comp("Mask").layer(thisLayer.name).content(5).content("Shape 1").content("Path 1").path
This one doesn't:
index = 5;
comp("Mask").layer(thisLayer.name).content(index).content("Shape 1").content("Path 1").path
Does anyone have an idea on why?
I am using CS6 on Mavericks.
Thanks a lot!
Diego
Dan Ebberts
Re: Expressions and contents problem
on Jun 4, 2014 at 3:53:54 pm
One thing I see is that "index" is a reserved word representing the layer's order in the layer stack. So setting index = 5 won't do anything and when you refer to index in the next line, what you'll get is the index of the layer hosting the expression. Try something like idx instead.
Dan
Diego Mellado
on Jun 4, 2014 at 5:27:04 pm
So obvious I feel stupid...
Thanks a lot!
D!
