Leader Expression with leader
COW Forums : Adobe After Effects Expressions
Joao Monteiro
on May 22, 2014 at 12:26:55 pm
Hi All.
I've got a Eps logo which is a word.
I've precomped it and duplicated 10 times (it has 10 characters).
I've masked each individual letter in each comp, so I have the characters all separated.
I've animated my Leader which is my first pre comp layer, which does a basic movement on the y Axis.
Now I want the others to follow, incrementing a step at the time. Cascade effect.
Follow Y position (keep X and Z - In this case is the same as my pre comp has the same anchor and position) and delay it by 0.16 (4frames on a 25fps comp).
How can I achieve this?
I was trying to do it but I'm not even close I guess.
transform.position[0];
thisComp.layer(index-1).transform.yPosition;
transform.position[1];
delay= thisComp.layer(index+1). delayFrames*.16;
leader= thisComp.layer("P-leader");
Joao Monteiro
Joao Monteiro
Re: Leader Expression with leader
on May 23, 2014 at 8:28:09 am
Or should I use valueAttime() ??
Thanks a lot.
Joao
