wiggle AND loop expression issues
COW Forums : Adobe After Effects Expressions
David Ochudzawa
on May 19, 2014 at 12:44:46 am
I'm trying to wiggle and loop a shape I have keyframes in the Z rotation but it only reacts to the top script and not the bottom one. Its driving me crazy. If I swap the scripts then it will change reactions to only read the very top scrip. Here is my scrip and I need them both to work simultaneously -
Please help, What am I doing wrong??
loopOut("cycle")
wiggle(50,15)
Dan Ebberts
Re: wiggle AND loop expression issues
on May 19, 2014 at 1:53:24 am
The expression engine doesn't know how to combine those results. The last thing it calculates is what it takes as the value. Are you trying to wiggle a loop or loop a wiggle?
Dan
David Ochudzawa
on May 19, 2014 at 2:26:26 am
I'm trying to loop and wiggle the same rotation. I first created the loop as i want it to continue as long as I need, and then I wanted to wiggle the shape rotation thats looping.
Dan Ebberts
on May 19, 2014 at 3:24:06 am
See if this is close to what you're after:
loopOut("cycle") + wiggle(50,15) - value
Dan
David Ochudzawa
on May 20, 2014 at 1:28:28 am
THAT WORKED!
Thank you Dan. It was so hard to find out how to to the linking. Very much appreciated.
So I need to add a + between any script and end with - value at the end.
Dan Ebberts
on May 20, 2014 at 3:00:58 am
Not exactly. The - value is used isolate the wiggle amount. Generally though, you would store the result of the first calculation into a variable and then combine it with the result of the second calculation. The specifics will depend on what you're trying to do.
Dan
