Expression moving keyframes
COW Forums : Adobe After Effects Expressions
Marek Ištok
on May 15, 2014 at 2:38:31 pm
I want to be able to move an existing keyframe (for example a whole set of "outro" keyframes) to a different frame. The reason is, I want to be able to just say, the video is long [something] so move the outro "stuff" to the end.
If you didn't understand this explanation, just tell me, I will go more in depth.
-Thanks in advance
Dan Ebberts
Re: Expression moving keyframes
on May 15, 2014 at 3:46:37 pm
Expressions can't move keyframes. In some situations though, you can get around that by having the expression re-time the animation based on other conditions (markers, for example).
Dan
