stop keyframes from animating using an expression?
COW Forums : Adobe After Effects Expressions
carLos bautista
on May 7, 2014 at 9:09:54 am
hi guys,
just wanted to ask, if there's an expression to stop keyframes from animating using an expression?
e.g. if there are 2 keyframes for the position property,
then if i put that that certain expression, it wiLL not proceed
to animate
is there such an expression?
whats the use for me? why not just deLete the keyframes right?
but i dont want to deLete the keyframes, i wouLd Like to have an option to on/off it as i want to, if ever i change my mind to put the animation back again..
Todd Kopriva
Re: stop keyframes from animating using an expression?
on May 7, 2014 at 2:29:43 pm
You can just have an extremely simple expression that sets the value of the property to a constant.
After Effects team blog
Dan Ebberts
on May 7, 2014 at 4:21:35 pm
Something like this should hold the value occuring at the layer's in point:
valueAtTime(inPoint)
Dan
carLos bautista
on May 9, 2014 at 8:49:50 am
this works.. :)
super thankx dan!
