controlling an expression depending of other value
COW Forums : Adobe After Effects Expressions
Ivan Salmeron
on Apr 13, 2014 at 7:29:42 pm
Hi guys, i've a work to deliver where, if no one can help me, i will have to edit manually about 1200 layers :ooo
The thing is that, i have a lot of lights from 3D which im using with particular as particles emissor. The thing is that the lights are emitting particles even when they are not in movement, and i dont want that so i want to use the light intensity to control the particles emitted from those lights (which have different in/out point)
So i want to tell after effects this thing, in a language which he could understand... :P
IF the position of the light is the same as the previous frame, then intensity = 0
IF the position is different than the previous frame (its moving), then intensity = 100.
Is this possible, could someone help me?? thanks in advance
Dan Ebberts
Re: controlling an expression depending of other value
on Apr 13, 2014 at 9:25:20 pm
Maybe something like this:
spd = thisComp.layer("Light 1").transform.position.speed;
Math.abs(spd) > 0 ? 100 : 0
Dan
Ivan Salmeron
on Apr 13, 2014 at 10:15:37 pm
ill try it first thing in the morning, if that works you saved me lot of hours of work :)))
Ivan Salmeron
on Apr 14, 2014 at 6:02:16 am
it worked like a charm,i love you so much! haha
