Expression - random numbers with decimal point
COW Forums : Adobe After Effects Expressions
Robert Cornfoot
on Mar 7, 2014 at 9:18:31 am
Hello
Firstly can I say I am new to expressions. However I would like to know if there is a simple way of generating a random number with two further numbers after the decimal point.
e.g. 15.17
I have used the 'Character Offset' with a wiggle command - wiggle(1,5) but this only produces a two digit number with no decimal.
Does anyone know a work around?
Rob
Dan Ebberts
Re: Expression - random numbers with decimal point
on Mar 7, 2014 at 4:10:43 pm
I'm not sure if this is exactly what you had in mind, but give this source text expression a try:
random(100).toFixed(2)
Dan
Robert Cornfoot
on Mar 8, 2014 at 4:14:05 pm
That's fantastic thanks - just what I wanted.
One further question. Can the speed of the random numbers be controlled? (slowed down) For example, can the time between each change of digits be extended - so the each digit is on screen for longer.
Rob
Dan Ebberts
on Mar 8, 2014 at 4:38:36 pm
Something like this probably:
frames = 5; // frames to hold each random number
seed = Math.floor((time - inPoint)/framesToTime(frames));
seedRandom(seed,true);
Dan
Robert Cornfoot
on Mar 9, 2014 at 2:35:55 pm
Thanks a million Dan. Perfect!
Rob
