flipping positive for negative from rotation controller
COW Forums : Adobe After Effects Expressions
Mike roberts
on Mar 4, 2014 at 2:26:52 am
Hey guys,
I have a null with the y position being affected by the rotation. when you rotate the null into the negative, the y position moves down... very simple:
value - transform.rotation*5
what i need is something in there so that when the rotation is positive, the expression changes to:
value + transform.rotation*5
To try and explain further - i want the y position to go down the same amount when the angle of the rotation is at +15 or -15, 0 degrees being the highest point.
Is that doable??
Mike roberts
Re: flipping positive for negative from rotation controller
on Mar 4, 2014 at 2:48:54 am
I DONE FIGURED IT OUT!
value + (Math.abs(transform.rotation*5))
is there a better way??
Dan Ebberts
on Mar 4, 2014 at 3:23:37 am
That's how I'd do it.
Dan
Mike roberts
on Mar 4, 2014 at 5:27:20 pm
Thanks Dan!
