simple move expression
COW Forums : Adobe After Effects Expressions
Simon Bisset
on Feb 28, 2014 at 11:58:06 am
Hi everyone. First time here, so hope you can help!
I am using a 'Hole' effect and have pick-whipped from the effects Centre to the position data on a Mocha Move NULL object (some tracking data).
So far so good, and I have the expresion:
thisComp.layer("Mocha Move NULL").transform.position
This works fine, but I now want to fine tune the x,y data more accurately to place the Hole centre where I like. So my question is, what additional text do I need to add to the expression above to do this?
Many Thanks,
Simon
http://www.focal-point.co.uk
Dan Ebberts
Re: simple move expression
on Feb 28, 2014 at 3:49:32 pm
Do you mean you want to add a static offset? That could be done like this:
xOffset = 50;
yOffset = -25;
thisComp.layer("Mocha Move NULL").transform.position + [xOffset,yOffset]
You could tie xOffset and yOffset to sliders if you want to be able to adjust manually (or keyframe the adjustment amounts).
Dan
Simon Bisset
on Feb 28, 2014 at 4:35:41 pm
Hi Dan, That's perfect!
Thanks very much.
Regards, Simon
ps, check out my film to see what i'm up to ;-)
http://www.criteriaone.co.uk
