Text and Markers expression issue
COW Forums : Adobe After Effects Expressions
Levi George
on Jan 9, 2014 at 6:11:08 am
Hi!
So I'm working on an animatic template where a text asset can read into the markers on a comp and display the shot number. I'm using Markers at the start and end of each shot, where each cut is. It means I can drag these markers around and the label will update automatically. I'll eventually expand this for frames and shot length etc.
I put some code in a text object hoping the text would display the correct shot number.
but as soon as it moves onto the second Marker it just reads
[object layer]
My code is below.
Thanks for your help in advance.
for (
n=1 ;
time>=thisComp.marker.key(n).time && time<thisComp.marker.key(n+1).time ;
n++)
{value = n} ;
Dan Ebberts
Re: Text and Markers expression issue
on Jan 9, 2014 at 6:23:31 am
It should be close to this:
m = thisComp.marker;
n = 0;
if (m.numKeys > 0){
n = m.nearestKey(time).index;
if (m.key(n).time > time) n--;
n
Dan
Levi George
on Jan 12, 2014 at 3:06:24 am
It was exactly that! Thank you very much!
