expressions and popup windows
COW Forums : Adobe After Effects Expressions
Theo van Laar
on Dec 13, 2013 at 8:59:55 pm
Expressions are normally added to the timeline. However, when you buy expressions like the iExpressions from Mamoworld, then the output can be adjusted in a new popup window. Are those windows also created with expressions? Is it possible to create such a window for our own expressions? How would that work?
Thanks for your reply.
http://aescripts.com/iexpressions?utm_source=aescripts+%2B+aeplugins&utm_ca...
Theo
Dan Ebberts
Re: expressions and popup windows
on Dec 13, 2013 at 9:31:31 pm
Expressions can't create dialogs or windows. You'd have to use scripting for that. All that scripting UI stuff is described in Adobe's JavaScript Tools Guide which you can get to from the Help menu of the Script Editor.
From AE: File > Scripts > Open Script Editor > Help > JavaScript Tools Guide
Dan
Theo van Laar
on Dec 14, 2013 at 11:57:47 am
Theo
