Making an object change color every 90 degrees
COW Forums : Adobe After Effects Expressions
David Mathis
on Nov 24, 2013 at 6:41:01 am
I would like to animate a star shape and have it change color every 90 degrees. Would it be necessary to convert to radians first? If my understanding is correct 90 degrees is the equivilant of 1/4 radian. The first part of the expression I am not positive about. That would be converting degrees to radians so any help is very much appreciated.
Dan Ebberts
Re: Making an object change color every 90 degrees
on Nov 24, 2013 at 8:00:28 am
You only need to use radians if you use JavaScript's trig functions. For what you want to do, degrees should be fine. This will increment every 90 degrees
Math.floor(transform.rotation/90);
You didn't mention how you wanted to relate it to color though.
Dan
David Mathis
on Nov 24, 2013 at 5:38:14 pm
Thank you. As far as the color scheme would go I would want the color to be as follows:
At a value of 90 degrees red
At a value of 180 degrees blue
At a value of 270 degrees green
At a value of 360 degrees yellow
I want to the process to start over again after the rotation is greater than 360 degrees, if possible. I can get the the expression to work until it goes past 360 degrees then it stays yellow.
There are two expressions below. One is a slider that and the other is for the color.
Probably something I am overlooking is simple. Thank you again for your response.
For the slider control:
r = transform.rotation
if (r&lt;0) r*-1
else r
This expression will be used to return a positive value even though the rotation is not. This expression will be to create the next expression.
Color expression:
r = effect("Slider 1")("Slider");
if (r>90 && r&lt;180) [255,0,0,1]
else if (r>180 && r&lt;270) [0,255,0,1]
else if (r>270 && r&lt;360) [0,0,255,1]
else [255,255,0,1]
Dan Ebberts
on Nov 24, 2013 at 6:10:13 pm
This should work (with positive or negative rotation values):
colors = [[1,0,0,1],[0,0,1,1],[0,1,0,1],[1,1,0,1]]; // red, blue, green, yellow
idx = Math.floor(Math.abs(transform.rotation)/90)%colors.length;
colors[idx]
Dan
David Mathis
on Dec 1, 2013 at 7:07:22 pm
Thank you! The expression worked but now I have another question. I would like to add a check box to determine if I want it to change color or have the color set to whatever I choose with the box not checked. I tried the expression below but kept getting an error message.
change = effect("Change Color")("Checkbox")'
if (change == true): {
colors[idx]
} else {
value }
Dan Ebberts
on Dec 1, 2013 at 7:17:08 pm
I think there are just a couple of typos. This should work:
change = effect("Change Color")("Checkbox");
if (change){
colors[idx]
}else
value
Dan
