Random Number Counter with expression slider not pass zero
COW Forums : Adobe After Effects Expressions
Bert Beltran
on Oct 28, 2013 at 6:32:34 pm
I have an text layer were the source text is parent to a expression slider. The expression looks like this:
Math.round(effect("Slider Control")("Slider")). Then I added a wiggle expression to the slider control, but my issues is that the wiggle expression sometimes runs into negative numbers and I want to set the minimum value to Zero.
I tried this expression that came close to doing what I wanted it to do but there are times it will jump to a negative number.
Math.min=0;
wiggle(1,50)
Last thing how would I create an expression so that it has a max limit number as well. So that it did not pass the number 100. So it would count random numbers from 0 to 99.
Muchos Thank You's
Kevin Camp
Re: Random Number Counter with expression slider not pass zero
on Oct 28, 2013 at 6:44:53 pm
Math.min() and Math.max() need two values (unless they assume zero as one value if only one value is present).
so for your first expression you'd want something like this:
w = wiggle(1,50);
Math.max(0,w)
you'd use Math.max() since you want it to return zero if w is less than zero.
to values to a range (0-99), you'd use both Math.min() and Math.max(), and you can embed one inside the other:
w = wiggle(1,50);
Math.max(0,Math.min(99,w))
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Kevin Camp
on Oct 31, 2013 at 9:33:17 pm
clamp() would also work here...
w = wiggle(1,50);
clamp(w,0,99)
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
