Adding selected item in project panel to a comp
COW Forums : Adobe After Effects Expressions
Shahrokh Jahanzadeh
on Aug 17, 2013 at 1:22:19 pm
Hi there...
I have a simple question
I looked over the internet and I didn`t find my answer but this post helped me a little: http://forums.creativecow.net/thread/227/17300
here is my question: How can I add a selected footage from project panel to a comp with scripts???
Shahrokh
Dan Ebberts
Re: Adding selected item in project panel to a comp
on Aug 17, 2013 at 4:09:12 pm
Something like this:
var myComp = app.project.activeItem;
for(var i = 1; i <= app.project.numItems; i++){
if ((app.project.item(i) instanceof FootageItem) && app.project.item(i).selected){
myComp.layers.add(app.project.item(i));
Dan
Shahrokh Jahanzadeh
on Aug 18, 2013 at 4:39:27 am
Thanks Dan.
this code worked perfectly but there is a new problem...
your codes worked when we selected Comp panel or timeline panel
and when I added this new line in top, it didn`t work because the project panel will select.
app.project.importFileWithDialog();
How we can fix it?
Shahrokh
Dan Ebberts
on Aug 18, 2013 at 5:48:13 am
Did you try making your new line the second line? If that won't work for you, I guess you'll have to go through the project bin and find your comp by name.
Shahrokh Jahanzadeh
on Aug 18, 2013 at 5:56:09 am
Oh my GOD...
No I didn`t try, I really forgot this one...
that way worked perfectly
You are the BEST
thanks Dan
Shahrokh
